[email protected]
New User
I need help understanding the connections for the auxillary control valve which controls the remotes on my 180. I need to replace (or repair) the valve and want to be sure I understand what's needed before I start. The picture shows the valve looking from the right front; as installed the handles are to the right and below the seat and the control valve is under the seat.
Question: Are the VALVE lines labeled 2 (which are connected to the left side of the valve assembly) the INLET and OUTLET valves? If so, which is the INLET?
Question: What is the purpose of the BLEED Line #3? The potential replacement valves (Prince and NorTrac) I have looked at have no such lines.
Has anyone replaced this valve? If so, what brand and model did you replace it with? How about a rebuild kit; is there one available?
This and any other info you can provide will be much appreciated as I am not much of a mechanic. THANKS.
