TractorLinks.com
Show Parts for Model:
Massey 202 stuck in 1st gear
chuck t
09-10-2017 18:10:40
Gear shifter is locked in first. Hi/lo shifter is fine. Forward reverse works fine. Any ideas?
ptfarmer
10-01-2017 20:25:47
 Re: Massey 202 stuck in 1st gear in reply to chuck t, 09-10-2017 18:10:40
Then you need to pry the big gear to the back to get it out of first gear, and back into neutral (when you put it in first gear the shift lever moves the big gear forward)
chuck t
10-01-2017 15:34:10
ptfarmer
10-01-2017 09:26:58
With the 202 the reverse is "locked out" of where it would normally be because the reverse is in the shuttle shift next to the L-S-H shift lever.
There is a pin that holds the shuttle, and high, and low levers in because they use the same hole. If you can knock that pin out to the right hand side you can simply remove the shuttle, and high low levers together (there is noting that can fall into the transmission). Get the shuttle back into neutral, then put the levers, and the pin back in. There maybe an easer way to do it, but I've never had to un-stick the actual shuttle shift.
ptfarmer
10-01-2017 09:06:13
QUOTE: Getting the main shift lever unstuck Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse. Pry the big gear back if it is hung in first gear. If you happen to go to far it will go in the other gear. If hung in second or third gear you have to pry on the shift fork you can see through the filler hole. If hung in second pry the fork toward the front of the tractor. If hung in third pry the fork toward the back of the tractor. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them
chuck t
10-01-2017 07:57:32
I tried the procedure but can't get the gear to move. Do I need to tap it, afraid to smack it hard. toward the rear? Had it in neutral and could roll the tractor, so no pressure on it. It's the big gear that's slightly to the front of the hole that I'm trying to push back, correct? The forwardreverse in the 202 is the shift lever, (shtlltle shifter?) so reverse is not on the gear shifter.
Bob in Tennessee
09-13-2017 11:36:50
John Deere D is exactly right. You do not need to remove steering gear box to access gears. use a powerful flashlight and stout flat screwdriver and you will be able to get unstuck. I have not unstuck thousands but I have done a few.
Larry in WNY
09-11-2017 18:31:41
It may also help to jack the back wheels off the ground and rotate them by hand to get the oil coating the gears and sliders. Then try working it free with a bar. Our 202 was stick and this helped.
Larry
John Deere D
09-10-2017 22:34:50
Located this info in the Archives:
Massey Ferguson 6 speed transmission: 3 speed with High Low Range
Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. If hung in second or third gear you have to pry on the shift fork you can see through the filler hole. if hung in second pry the fork toward the front of the tractor. If hung in third pry the fork toward the back of the tractor. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them
