So, I thought my clutch was gone. Me and a buddy split the tractor and find an
oily mess. The clutch had plenty of oil soaked meat. Changing it anyway. We
are sure we need to check the trans oil seals. BTW,dual clutch transmission. We
have loosened the powering shaft housing and the manual tells us to drop the pto
drive shaft gear. We got the pto plate bearing and housing off, but are now
stuck. Does the thrust washer remove without trickery so we can get at the snap
ring to remove or drop down the pto gear so we can remove the link power shaft
to replace the bearings and seals? BTW, are all these snap rings OTC items?
Thanks for any help. Losing friends.
