Just finished rebuilding my z145 and got it fired up. Finally.... When i first started it the oil pressure was about 30. I ran it long enough to get it up to temp twice. First to re-torque the head bolts and once to adjust the rockers. The pressure at idle is now sitting at 10 and making some not so happy noises. The rockers barely get any oil, like only a couple drops. Did rebuild the pump and packed with grease for initial startup. I know the rear main bearing is installed correctly with the large holes towards the block per manual.
What am i missing here?
