jon_schram
I have a MF 202 (1963-ish) with power steering. Looks like the system is cobbled together off of another tractor...probably a MF50 or MF 65 because that's what he had for "parts tractors."
Anyway, the PS works great, but it does leak. I ordered a filter off of this site, and it is clearly of a different design than what is in there. The new filter will fit inside the reservoir, but it is smaller than the one that's in there. I can't imagine that being an issue at all.
I was planning on dumping a quart of Lucas PS stop leak into the system, but I doubt it will stop the leak...which appears to be where the unit mounts to the block. If the PS system leaks, and I am continually dumping fluid in, is there really any reason to even have a filter in there? My MF 135 has a different PS system, but I think it was ran for years and years with no filter.
If the system leaks I would think the junk is finding its way out as well. And adding fluid makes a mess with the filter splashing fluid when I dump it in. Plus, it would hold more fluid and I could probably avoid adding as often.
Any problem (like flow rate, etc) that I'm over looking here? I'll drop this filter in since I have it, but in the future I'll probably just run without unless there is some other reason besides "filtering" the fluid that's leaking out anyway.
