MF 30E Banjo bolt washers?
awi2035
New User
I'm looking for the banjo bolt washers for the fuel lines on the injector pump on my Massey Ferguson MF 30E. I can't seem to find the correct ones. Any suggestions?
Thanks. We ordered a kit for the injector pump and the washers came in the kit. We have replaced washers, seals, gaskets and filter in the injector pump. We are reassembling it. We have discovered the idling spring is missing. Now we are on the hunt for it. Apparently it had been taken apart before. The governor spring was in the wrong holes and the idling spring is missing. According to the attached diagram the code number stamped into the injector pump is 6 so on the chart find the 6 and that will tell what holes in the throttle shaft link and the governor arm the governor spring should be in.
