Massey Ferguson 210-4
Quinto
New User
I am new to the forum and also a newbie to tractors in general. I bought my first (compact) tractor a few years ago - a MF 210-4. Its been a great little workhorse. I have some trouble with the right front drive assembly. I have removed the outboard hub assembly and I have been able to source most of the bearings, CV joint etc. that I need at our local dealership, but it seems MF no longer supports this model and they do not have the spindle thrust bearing and seals, hub seals or the top bearing and seal. My questions to the greater MF world:
1) Where is a good source for hard to find parts? This model was manufactured in Japan.
2) The service manual has a general note that says the manual will describe service of complete assemblies (i.e. the complete front axle assembly). They go on to say partial assemblies can be serviced but this will depend on the judgement of the mechanic. So my specific question is: can I remove the front right axle housing and axle without removing the complete front axle assembly and differential? It looks like there is a STOP welded to the frame that might prevent the removal of the right and left axle housings without first removing the entire axle and differential from the tractor.
I apologize if this is a rookie question and a tad wordy. I am however, a rookie and will appreciate the expertise and advice of seasoned experts!
The Hinomoto tractor made for Massey Ferguson, the Hinomoto MF tractor is similar to the Allis 5020, Simplicity 9523, and Hinomoto E23. Hinomoto got bought by Hitachi Tierra, but they haven't built any tractors for man years so finding Hinomoto parts is going to be very hard if not impossible. You maybe able to match up some bearings at a place that sells bearings, seals, etc.
The 210-4 tractor was manufactured by Hinomoto while the 2 cylinder diesel engine was manufactured by Toyosha. so I believe the parts i am looking for originated at Hinomoto. I will enquire at our local bearing supplier. Thanks Dieseltech!
Thank you ptfarmer, I am currently checking with our local bearing supplier, thanks for your guidance!
Hi Quinto
I may be able to find the parts you need...Contact me through my E-mail...bottom right. Classic view.
Wayne
So glad to know who built the tractor I so dearly like.
