Our Farmer
Started losing trans lube through the weep hole big time, so bit the bullet, split the tractor and changed the output and PTO output shaft seals. The Front PTO drive snap ring got a little boogered and bent up pulling it out, so I'd like to put in an new one, but find a part number. The output shaft is 1 1/2" in diameter, the snap ring is about 1/32" thick.
Is this a common part I can find at an auto or bearing supply house? This site doesn't list one, and there's no MF dealer anywhere near me. If anyone has a part #, would be much appreciated.
Thanks.
Thanks.
