1962 MF35 air cleaner
Rumgully
New User
Hey guys! I was looking for an air cleaner housing assembly for my old MF with a Perkins. I have searched for parts numbers and have not been able to find any. My air cleaner isn't round like all the ones I see and I have developed a rust hole in the cup that holds the oil. I have an oval shaped air cleaner. will the round aftermarket assemblies that I see on other sites work on my tractor? Also, I need a fuel line that goes to the heater plug. Any parts number for this item?
Here are some pictures from a Parts Manual I have:
Parts Book FORM NO. 651 093 M91
6M-10/60
Any of the items you require on these parts pictures?
If you identify the parts you require I shall post the Parts Numbers:
Bob.....
Need part #'s for 22, 29, 26 with the air intake.
Need parts # 24 with the fuel line.
Thanks for the help Bob!
#22 187 467 M92 Air cleaner Assembly :
#29 187 498 M1 Air Inlet Scoop Tube :
#26 187 502 M1 Air cleaner to Manifold Hose :
#24 187 014 M91 Tank to heater (Incl. Items 25 and 26) Line assembly :
Bob........Northern Alberta Canada....Owner operator 1963 MF FE 35 X 3 cylinder Perkins
So I can't find any aftermarket or original parts to match the air cleaner. There isn't anything to weld to. Even if I get the hole patched, the gasket is shot. This is not going to be a show tractor. Any suggestions on what to do for an intake filter?
Quote:will the round aftermarket assemblies that I see on other sites work on my tractor?
I own and operate a MF FE 35 made In England, with the 3 cylinder Perkins 3.152 Engine:
I'm unable to address your concerns, however, here are some pictures of a MF FE 35 3 cylinder Perkins Diesel:
Bob..
