MF 35 gas/ Radiator cap and Gas cap same as diesel version
bcraig2N
Is the Radiator Cap for a MF 35 with the Z134 Continental engine the same as the Cap for a diesel Version?
Is the Gas cap for a MF35 with the Z134 Continental engine the
same as the Gas cap for the diesel version?
Are the hood latch bolts the same for a Deluxe Version as a standard version?
I am compiling a List of things that I need to get for my
MF 35 Deluxe with Z134 Gas engine.
Thanks
Craig
The radiator caps are the same.
The fuel caps are the same for most 35s, but there is a serial number break where they used a different cap after serial number 233722.
the only difference I can find on the hoods is the grill and grille brackets, where there is another serial number break....231863.
If you need some parts...I do have some and can get some others.
Wayne
Thanks
I am not talking about the Panel knob though
I am talking about the bolts that hold the entire hood to the console. The ones that are on both sides of the tractor that have wing nuts that slide into slots on the console(I guess thats what it is called)
I cant figure out how the other ends attach to the hood.
I only see a hole on both sides but looking at the latches(bolts) they dont seem shaped right.
Would you explain to me how they work?
