New guy here and I need some help. I purchased a MF135/ MF2135 awhile back and stored it intending to fix some problems later. My tractor implement lift hydraulics was not working so I took the oil dipstick plate off and found there was no lift pump lever in place. I removed the lift cover and found several problems. I have fixed several problems, including removing the lift pump, replacing some roller pin bearings, installing a lift pump control lever (also bought a roller for it), and reinstalling the lift pump. Problem is that the vertical draft and position levers coming down from the lift cover linkages do not line up with the lift pump control lever. So what is wrong? Do I have the wrong lift pump or what? I attached a Picture.
