question for ptfarmer
Dieseltech
Location
Akron, Indiana
Any chance you would have a UK 135 diesel parts book? This odd duck I have here has the power steering cylinders on each side of the front axle, and a spool valve under the dash similar to the 50-65-165 models that has the same type linkage that moves up/down when the wheel is turned. Original grill is missing, left step plate has a lockout lever to block the pedal out of the second PTO release stage when not needed. Dash SN tag shows 429119, has no 9A prefix like the US models do. Also equipped with the Lucas "prince of darkness" starter and generator. Thanks in advance.
Dieseltech, you should be able to access 135 UK (135 GB) parts in the North America AGCO online parts book. I found the 165 UK parts in the AGCO North America online parts book. Some of the of the UK stuff is accessible to us here in the states in the online parts book.
Thanks, I'll try that. Tonight I could not get on the Agco parts site like I usually can. Maybe it will work tomorrow. The power steering on this 135 is not at all like the US models sold at the dealer I worked for years ago..
