I have a question about what is normal for the 3 point lift on my 175. I was going through some hydraulic checks and adjustments. I noticed that when the engine is stopped the 3 point lift will allow the attachment to lower to the ground. With the response control cover removed I notice that fluid sprays out of the small pin hole in the control diaphragm. That seems to be the point where the hydraulic pressure is relieving from. I don't notice any other fluid leaking anywhere else. The main pump and control valve are new. The lift cylinder is new too and has a Teflon piston with no leakage there. Is it normal for these tractors to not hold the load with the engine off? If not then any suggestions?
Thanks
Thanks
