Massey 235 fluid pouring from pitman arm
Troy S
New User
I have a 235 Massey that power steering fluid is pouring from the left side of the gear box at the pitman arm location, Is there a seal that can be replaced to fix the problem without tearing the box down.
if it's leaking power steering fluid the hyd. cylinder shaft seal is most likely leaking into the steering box, neighbors was doing the same but he also had some other parts worn out, he was shocked at what the cost of the parts needed to rebuild his unit, don't know if he ever rebuild it or not.
