1105 hydraulic pump face plate bolts striped?
hayray
The face plate on the end of the hydraulic pump drive shaft which bolts onto the crank pully is mounted with 4 or 5 bolts of which
most are stipped out. Seems like I will have to remove the hydraulic pump in order to get in there to drill and tap. I already put
new bolts in and that didn't work. Right now I have about 2 bolts holding but the pully is not on there very tight.
Seems you said in an earlier post the pulley was not turning, That pulley is bolted on from the back side of it, just looking at Agco parts book, CRANKSHAFT AND FLYWHEEL is what I had to look at for a diagram of it!
The pulley is turning and still operating the hydraulics, I just want to fix the issue before the remaining two bolts strip out also. Just wanting to know how much work it is to get that out?
Pump drive flange bolts to the center of the main pulley with 4 bolts. Pump shouldn't be that hard to remove other than it's heavy. Pump drops out the bottom.
Ya several years ago took the one out of our 1105 and seems like had to loosen the front axle and move it forward some.
