MASSEY 41 DYNABALANCE
RCTHAYER
New User
I broke the connecting rod for the blade head. the connecting rod that goes to the cam. I am trying to get it apart to see what else I need to replace but so far there are some damaged spacers and seals. I cannot seem to get inner half of pulley off. is there a woodruff key in there? I do have the parts manual but I cant seem to figure out how to dismantle the rest of this so I can see what parts I need. any help would be greatly appreciated. I want to remove cam and all parts and rebuild so a parts source would also help me out thanks
bob
Good luck on finding parts. I'm not sure if they are available from MF or not but that mower is about 50 years old. I have one I an still using and it is the best mower I have ever used. Bought up all the old ones I could find in this area for parts but my supply is getting low now. Main problem with them is neglect of lubrication of the crankshaft needle bearings. I grease mine every day I use it. Never heard of that part breaking,
Just got thinking and I think if you remove the 3 bolts that hold the bearing cup and pulley on you can pull it out but you will need to remove the 2 shafts that go through the counter weight and knife lever. Last time I had mine apart I think I took the whole drive assembly off and it was a lot easier to work on. If you have a parts book the layout is well displayed.
