Hi
I have a Massey Ferguson 35 Deluxe with the gas Z134 engine.
I just got it and checked the engine oil and it is about 3/4 Quart low.
oil seems very clean.
My Manual says to use sae 30 for uses above 90 degrees and that is the temps I will mainly use the tractor.
Just Curious whether I Can use a Regular 10w30 or 10w40 that is Detergent or if I need to find the Sae 30 wt Non detergent ??
When i took the gas cap off I saw that there was a lot of corrosion on the cap so I am going to change the cap.
Should i get a vented cap or a non vented cap or does it even matter??
I am going to replace the radiator cap as well.
Which Kind of radiator cap is recommended??
This is my first Tractor and I really appreciate the help.
