Seal - Front Timing Cover MF 35X
What's involved in changing the front timing cover seal for my MF 35X? How difficult is this?
Does the cover need to come off? Do I have to take apart the front end axle support?
Thanks
Scott
Remove Front AXEL,AXEL Mounting Support to Engine, Radiator and RADIUS ROD ASSEMBLY supports as one unit:
Remove crankshaft pulley:
Insert a SHEET METAL Screw into the Face of the Crankshaft OIL SEAL. Remove SEAL with SLIDE Hammer or appropriate tool:
If Seal does not have a METAL FACE then remove SEAL by what ever means safely without damaging the ALUMINIUM BORE that the O/D of the SEAL fits into:
Clean as per required and Install new OIL SEAL:
Bob...
