splitting to replace aux pump question
i got most stuff off the tractor and getting ready to split, from the lift cover hole i can see a line that goes from the front of the pump up towards the transmission, do you have to remove the shifter just to reach in and unbolt this line or can it be reached from the lift cover? it kinda looks like i might could get it from the lift cover if had a stubby wrench but not sure just thought id ask from yall that have actually went thru this before. just looks like a lot extra crap to unbolt for one line if i aint got to.
What model tractor for starters. I think what you're looking at is the line to the MP. If
your tractor has multi power it will require a double split at the clutch and behind the
transmission.
Okay. The275 is not one that i am familiar with so i will leave it to someone more
knowledgeable. Best advice i can give you is to find a manual.
I tried adjusting the linkage to the MP and now the rod is sticking up out of housing approx. 1 1/2 inch and wont go down , it would go up and down approx. 1/4 inch before but MP did not respond. Now it seems rod is out of position . Any HELP
165 mp diesel
