Hi again,...
I have been looking at the tractordata info, and it is just nonsense.
Look, your tractor is more or less a Massey Ferguson 165 with a 135 engine. Or, a 265 with a 240 engine. Or a 565 with a 550 engine.
All these tractors, including the MF 50, use the same centerhousing. And it takes about 28 liters or 7.4 US gallons of fluid, filled down the hole at the side of the gearleavers. This fills up the transmission and centerhousing and brakes since this is a tractor produced in 1977 when they had wet brakes. And this is for a tractor with normal 3 or 4 speed transmission with high and low in addition.
But, your tractor has the instant reverse transmission instead of the typical farm tractor transmission.
The instant reverse transmission has a smaller transmission part where the gear leavers sits, than the farm transmission. That is why it does not take as much fluid as the farm transmission, but only 6 US gallons. In front of this transmission the instant reverse part sits, with some gears and 2 clutches of the same type an automatic transmission in a car have. In addition it has a torque converter on the flywheel, and on the left side of the tractor you have a small filter, and in front of the radiator you have an oil cooler for the instant reverse transmission. And some pipes in between.
Under the instant reverse transmission you have a cover, and if you want to replace the oil in the instant reverse transmission you can open a small unbrako plug in the side of the cover and let it empty through that hole. When it is emptied you need to replace the filter on the left side of the tractor, sometimes at the side of the engine, sometimes at the side of the converterhousing/transmission, and you need to take down the entire cover under the transmission, and clean it out, and there is a screen up there you also need to either replace or clean in a solvent, or gas or something.
You can buy a new screen at your MF dealer, and I think it includes a new gasket. But, the filter on the pipe is not included in that as far as I know.
And, the oil needed for this is as I said in the Ferguson forum, 9,5 liters, or 10 quarts or in that neighborhood.
When you drain the oil from the centerhousing the oil in the transmission will not drain, there is a plug for that on the left side of the rear part of the transmission.
But, when you fill through the fillerhole at the side of the gearlevers, it fills up, and then it runs to the back end of the tractor.
And, as I said, you need to use a tractor universal oil intended for wet brakes. If not, your brakes will be gone.
They might call it hydraulics back there, but, the oil should serve as a combined gear oil, differential oil, and hydraulic oil. This means you can not use a pure hydraulic oil, because that will ruin your gears and differential.
A pure gearoil is not very good either, because it does not have the best hydraulic properties, except a GL 1 oil. And, a differential oil, can't be pumped very good, and neither of these oil can be used on a tractor with wet brakes. So, you are actually stuck with a tractor universal transmission oil.
And, as a rule of thumb, on all Ferguson and Massey Ferguson tractors from the TE/TO 20 series, and up to MF 100 series, 200 series, 500 series, 300 series, the oil is supposed to be up to so it comes running out of the bottom hole for the inspection cover where the dipstick sits.
I have no idea why Tractordata say 48 quarts. It has nothing to do with reality.
I have seen other errors on tractordata, to me it looks like there has been a conversion mistake from liter to gallons, or whatever it might be.
You mentioned if the dipstick could be wrong on the Ferguson forum.
Look, the dipstick is made of a piece or halfrod, and it goes up, and make that circle where you put your finger in, and down again a bit inside the hole. And, the markings are below that part. It is always around so if you are below minimum level, the oil does not come through the bottom cover bolt, and when it is at maximum level the oil comes out the hole. At leaast this is my experience with all the 8 Ferguson and MF tractors I have.
And, my MF 50, is no exception to this. A MF 50 industrial is the same tractor as you have, except it has either a 4 cylinder 212 engine or a 236 engine. But no more oil than your's is supposed to have, and certainly not less oil either.
I have a Jensales manual too, for a MF 50, but I do not have it with me here, so I can not control what it says about the oil figures.
But, yesterday I checked my owners manual, and that was the figures I gave you on the other forum.
Some inspection covers have the hole for the dipstick in different places, so therefor there are different dipsticks. But, the level is about the same on the tractor.
You mention that one dipstick is for tractor without hydraulics, on those the pump are removed and some have the original hydraulic cover with the holes blanked, and on others it is just a flat plate of steel over the hole where the hydrauliccover sits.
And then the other dipstick is for those with hydraulics.
Here is a clue for you.
On those with hydraulics they recommended more oil than on those without hydraulics. The figures I gave you is for a tractor with hydraulic pump.
So, if you use that figure, you are very safe if both you have a pump and if you don't have a pump.
The reason for less oil for a tractor with no pump is that the level will be stable no matter what, but if you have a pump and it pumps oil up in the hydraulic cylinder or out to an external cylinder the level inside the transmission is lower and then it can be too little oil for the gears and differential.
But, no matter if you have the pump or not, it does not harm the tractor to have as much oil as recommended for the tractor with pump. You maybe have filled a little more than you needed, but it does not harm.
I hope this helps some.
And, don't do maintenance based on tractordata figures. If you are unsure, get an owners manual from your MF dealer.
I could copy some from mine, but it is in Norwegian so it would probably not be so easy for you. Unless you are fluent in Norwegian.
Bill
