1105 pops out of gear?
hayray
My 1105 started a new trick, when I am in high range it will pop out of gear going down a steep grade. I have owned the tractor
for 14 years and it just started doing it now.
I had the same problem with my 1100 once. Found out the mice had built a nest under the linkages, and wouldnt allow the forks to go all the way into gear. open the panel at the bottom of your steering column and see if there is dirt etc, under the linkages.
Wayne
Had this exact situation on on 1135- there was a walnut from a critter underneath the linkage on top of transmission. Wouldn't let it go all the way in gear. Also worth pulling up a couple panels of the platform- the high/low linkage runs along the right side of the trans between the fuel tanks and the housing- gets built up with debris and doesn't like moving.
