135 power steering conversion kit
david9746
New User
Has anyone installed it? I am reading on line some kits have such terrible directions they may as well not have any. I would like to make sure this is not to hard and has decent directions.
I did some searching but no dice on this question.
Thanks in advance.
Dave
The units are typically from Turkey and the
directions are very poor (about 5 lines of
instructions with fuzzy pictures). The unit
I bought was for the 135s with a straight
front axle, not the swept back axle on
mine. They did not mention that. That made
it more difficult. Lots of fitting and
welding required in any event. When done
though the ram is very strong and the pump
and lines are good quality. Took me a day
to install it. You can then steer with one
finger.
Only thing I don't like about the ps kit from Turkey is the steering arms. From the looks of them they don't have the Ackerman angle in them correct, The Ackerman angle makes the front tire that is on the inside of a turn, turn more than the outside front tire on the outside of the turn.
A little. I had to bend the arm from the
steering arm to the ram a bit to avoid it
rubbing. The whole thing took some time
and adjustments to make it fit.
