I have a MF202 with the Z134 four cylinder gas engine in it. The old pump was leaking fluid into the engine so I put a new pump on it.
Am still having hard steering problems with it now. I had problems with hard steering and when I removed the reservoir cover the fluid was foamed up with air. After trying different fluids in it, I finally tried type A transmission fluid in it from advice I heard here on the forum. I am still having problems with it foaming up and hard steering.
What is causing this and what can I do to prevent it. I see no leaks anywhere in the system.
I drove it for a little bit yesterday and the steering was still hard. I did not remove the cover but I'll bet the fluid was foamed up
with air again.
The old pump seemed to work ok except for the fluid leaking into the engine problem. Any help would be appreciated.
with air again.
