Oilman galen
New User
1970-71 135 U.K. With pressure control. Trying to set high pressure on hydraulic pump. Manual unclear. Position control in transport, draft in dwn position, wedge holding dashpot out...? Once high pressure is set by adjustable wheel do u rotate position control quadrant to stop pump action. What is process for obtaining regulated pressure and not being in constant pumping once u have reached max pressure setting? Can anyone help??
Someone said 135 didn't have pressure control but that lift cover from a larger tractor would fit 135..not sure
I have 900 pound weight on lower links and when arms raise with pressure it seems like something might break once they make it to end of travel. What kind of top stop is there? Just check chains? What are length of chains to be?
