Cormiers Cove
Has anyone put one of these power steering kits on their Massey 35 tractor?
I'm curious how they function. I have read that you cannot use a loader if installing one of these kits. Something about components being in the way.
I looked at my uncle's MF 135 that has an Allied loader and his has power steering with the pump mounted on the right side of the tractor in behind the timing cover. I noticed his 135 does not have the radius arm assemblies (long steering forks) that bolt onto the front axle assembly. He has a short cylinder from each front axle bolted to the steering arm and the radius arm also bolts to the steering arm. His loader does not interfere with his Allied loader.
