Kurt in Va Beach
quick question on which way the MF165 oil pump pickup should be in the sump. Vertical or Horizontal? I have been having issues with my oil pressure for the past few years. when the tractor is started (cold) I have normal oil pressure. but after it warms up and get hot, the oil pressure would go to middle low and now is starting to show low/low after about an hour of use. so I figured it was the oil pump. but when I dropped the oil pan, the screen for the pickup was vertical. others that I have seen, mostly on cars, were always horizontal. vertical seems wrong to me as it could be sucking air, but am not sure as I have not a lot of experience working the MF tractors. so I thought I would put this to the experts out there. thanks for the help!
