Phil Tibbetts
Where is there a reasonably priced place to buy a pair of 12x24 or 12x28 rear rims with the center plate bolt pattern 8" 8 bolt holes? Mu cousin wants to replace his rear turf tires with R1 Ag tires.
I think you mean 8 bolt on a 6" bolt circle if it a 35, 135, etc MF tractor. Some Ford, and New Holland tractors also used the same bolt pattern wheels. A tractor salvage yard, or maybe craigslist would be places to look.
As asked what tractor?????????????????????????????????????? That info will help us know what your looking for since there are so many lug patterns out there
So, you actually need rear wheels (hubs and rims). Rims are "only rims" that go on a hub. It is very difficult to find good rear wheels or rims because they rust out badly over the many years. There are many sources for rims and wheels. Try YTMAG parts!
Look at some old tractors, most have welded up and patched rims.
The 205 has the outboard planetaries so the rear wheels from a 150, 65, 165, 203, 3165 that have the outboard planetaries should work. Some other model MF's with the outboard planetaries may fit.
MF 65, 150, 165, 175, 180, 231, 240, 245, 250. 255, 263, 265, 270, 271, 275, 283, 285, 360, 362, 365, 375, 390, 390T, 393, 394S, 396, 398, 399. Some of these may have the 8 on 6 wheels. I think the ones with the 8 on 8 have the 6" pilot hole (don't remember off hand).
International Harvester 240, 340, 385, 395, 404, 424, 444, 454, 484, 485, 495, 504, 544, 574, 584, 585, 595, 606, 656, 674, 684, 685, 695, 784, 785, 884, 885, 895, 4200, 4210, 4230, 4240, C50, C60, C80, C100.
Case 210, 310, 440, 430, 470, 530, 570.
Ford 420, 445, 445A, 515, 532, 535, 3500, 3550, 3930, 4000, 4000SU, 4100, 4400, 4500, 4600, 4610, 4630, 5000, 5600, 5610, 5610S, 5700, 6600, 6610, 6610S, 7000, 7600, 7610, 7610S.
All these wheels are 8 on 8, and should have a 6" pilot hole.
