My son's FE35 project
I posted a while back about my 16 year old son's project he bought. It's going well so far. Waiting for the engine to be done at the machine shop. Sandblasting, priming and painting.
Great Start!
Was this the MF FE 35 with the partially dissembled 3 cylinder Perkins diesel came with a new Head?
Bob...Owner operator MF FE 35 X..
I had to replace the Drive Coupling last month between the output shaft of the Transmission and the pinion drive of the Differential.
Here are several pictures:
I eventually removed the top lift cover as the Hydraulic pump was ruined...Brocken internal parts:
Bob.. Owner operator 1963 MF FE 35 X
Machine shop says new sleeves, pistons, rings, crank grind and new bearings, oil pump & thrust washers are needed. With the brand new head, this engine should last my son a long time.
What RPM on the Tachometer is the engine operating to give the standard PTO speed?
What is the MAX Engine RPM on the Tachometer?
There are several different Tachometers (Two that I'm aware of on the MF FE-35 3 cylinder perkins)depending on the year of the Tractor:
What is the Serial # of the Tractor:
Bob...I own and operate Serial # SNMY320137
Trying to post a picture but it won't. It's a Smith's gauge. If I'm reading it right it's 1500rpm for 538 pto rpm. Redline is 2,400rpm. It also says standard belt speed at 2,000rpm. The serial number is SNM221458.
