MF 165D tach weep hole
FinnMD
hello gents, seems I need to replace the gasket and seal as oil leaking from weep hole under tach drive. I expect it's fairly easy, but recall there is a certain way the seal needs to be placed. Would like some advice or if anything else unique I need to be aware of, and do I put any sealer on gasket or just gasket as is. Of course this happens in the middle of raking hay. Pic below. Thanks in advance. Finn.
