M-F 1010 -Again
Tim PloughNman Daley RIP
No one saw or could answer my previous post on a 1984 M-F 1010 diesel 4WD. So, moving on, who would have been the engine manufacturer on this? Alos,how do i check to see if the fuel injectors are working?
Tim *PloughNman* Daley(MI)
Parts for that are going to be hard to find, a crude way to test the injectors is to crack open a line at the top of each injector while it's idling, and listen to how the engine sounds after you loosen it. Then tighten the line, and do the next one.
