Let me start by saying I'm a mechanic and I have very little experience working on cars or engines. I'm not afraid to try.
This is a 1948 t0-35 that is on a 12v system.
The other day I was running a 1948 t0-35 and shut it down just like normal. I went to crank it back up and nothing. It acted like there was no power or it as if it were in gear. So I tried to trouble shoot it a little bit. I replaced the neutral safety switch. It still does the same thing.
So here what I have so far. I've ensured its in neutral. The battery is fully charged. I turn the key. push the start button and I have verified power goes to the neutral safety switch and then comes out the other side when I push the start button. that wire goes to the solenoid switch and I have verified power to the terminal there. The coil has power going to the + side as well.
I checked as many of the grounds as I could and they all seem to be in good shape.
I'm now stumped as to what could be causing this issue or how to trouble shoot it from here.
I guess it could be the starter but there is no noise what so ever when I try to start the tractor. any help would be great.
