power steering adjustment on 165
doorman
Rebuilt the cylinder on a 165 now if I tighten the tapered bolt between arms it doesn't activate cylinder. What is the procedure for adjusting linkage rod/ Thanks for any help.
With the tapered screw tight adjust the spool link/pins assembly so the pin is centered. Now BACK OUT the tapered screw 5-6 turns and lock it there. Steering assist cylinder will never work with the screw tight. System needs some play so the spool valve can move oil to the assist cylinder for left-right turns.
