I am lost on this one guys. I have a mf 175 with ipto and multipower. The multipower snaps right in and works great the pto can be stopped with a 2x4. So far I have replaced all the discs in the ipto clutch and put a new aux pump in and nothing has changed I have an it manual and friends with Massey knowledge but neither have helped with this issue. I got the tractor from a farmer that sold it when the pto quit. I put a 1000 psi guage in the test port of the left side cover and get no pressure before or after the new pump assuming the guage is correct. I've split the tractor twice now and both time cleaned out the belly and pick up screens for both pumps the seconds time was just because I was in there it didn't really need it and put new oil in. Nothing changes with the pto in fact it has gotten worse before i started all this it would spin my 7' mower just not fast enough to mow, now it won't spin it at all. What else can I check, clean, or fix. Is there a regulator on these systems or valve that could be bad? I did run it with the top cover off and nothing seems to be broken any input would be appreciated thanks guys!
