Woodruff key slots don't align with bolt slot
Another what to do? The two woodruff keys slots do not align with the bolt slots on the spindles. What now? Grind the slots for the bolts and try to align by adjusting tie rods? that is going to throw everything out of kilter. Using either slot leaves the bolt slot 8 or 10 degrees off.
If you have the swept back axle the spindles, and steering arms are the same for both sides.
If you have the straight axle with the adjustable width the steering arms are the same, but the spindles are right hand, and left hand.
If you have the straight non-adjustable width axle, the spindles are the same, but the steering arms are right hand, and left hand.
Never argue with a man who knows what he is talking about... my original spindles are the same, notched so bolt can go in either of two positions. One spindle they shipped is S.15987, Spindle, RH. I can't find my original order right now.
I think what you are telling me is I ordered the wrong spindles to start with. I ordered 897237M94 and 897236M94 and I should have ordered 2 of 508546M92. Correct?
(quoted from post at 14:17:30 06/23/17) I think what you are telling me is I ordered the wrong spindles to start with. I ordered 897237M94 and 897236M94 and I should have ordered 2 of 508546M92. Correct?
Yes on the ordering of (2) 508546M92 spindles.
