BillwithMF35
New User
Hi, I am trying to get my Massey 35 back to life. It stopped running while I was hauling a load of firewood and has been out there ever since. I took the carb for a rebuild (it didnt need any parts, my friend at the shop just cleaned it up and reassembled)--not the problem.
Late 50s (I think) Z134 gas engine.
Since the problem started, it hasnt wanted to keep running, just starts, runs a bit and dies. Then wouldnt do anything. Aside from the carb, I just changed: plugs, wires, points/condenser/rotor/dist cap. Couldnt find a new coil so that is still original. Spark is alternating blue/orange going into distributor.
Having changed all those ignition parts, I was back to: cranks,fires briefly, runs for a second, then quits.
I just took delivery of a new sediment bowl assembly so I am heading back out to try that. (definitely needed as the old one was leaking and shutoff valve gone wonky.)
To be continued.
To be continued.
