John Deere D
Installed new COUPLING between AFT out put shaft of Transmission and splined input shaft of diff. Pinion, new Internal HYD.PUMP, new Transfer Diesel Fuel Pump, all new gaskets, filled system with 15-40 OIL.
Had to split Tractor at TRANS./DIFF. Joint due to ongoing OIL Leak:
Spent several hrs.. slashing and all operated fine:
Thanks to "YT" parts supplier...
I must look around for a 60>72" Mower:
Bob....Beautiful June Day:
