John Deere D
My Brother in-law has decided to REPLACE the INTENAL 3 POINT HYD. Pump on his MF 175,four cylinder Perkins Diesel. His MF 175 has Multi-power, and possibly a PTO system that does NOT utilize the Dual Clutch arrangement like my MF FE 35 X.
I Located and purchased (for my Brother in-law) an ORIGIAL MF 175 Operator Manual, an ORIGINAL MF 175 SERVICE Manual as well as an ORIGINAL MF 175 Parts Book from a supplier in the USA.
Today I ran my MF FE 35 X on a PTO Slasher with a NEW INTERNAL HYDRAULIC PUMP and all ran perfectly!
My Brother in-law would like to install a KIT in my MF FE 35 X Hydraulic pump (old / used Pump) and then install said Pump in his MF 175.
Could someone please verify if the 1963 MF FE 35 X INTERNAL HYD.OIL pump will in fact fit into and work properly in a MF 175?
There are obviously several different brackets that would have to be transferred from the MF 175 pump onto the MF FE 35 Pump:
Pic. is of the OLD INTRENAL HYD. OIL Pump from my MF FE 35 X:
Thank you for any assistance:
Bob...
Bob...
