Tracy Brown
I was thinking that my pto clutch pack on my tractor was bad and needed repair. The lever does not cut it off. Loaded or not, it runs all the time (almost). Looks like a major job so I have been using it (carefully) as is for now. I know it is hydraulic engaged by pressure from the power steering pump. I also know the PS pump is not live and does not turn if clutch is depressed. I was thinking if the clutch pack is burned up and the pto runs all time, that probably the discs are warped locking it engaged. However, I have noticed that when I start the tractor, as long as i have the clutch depresses, the PTO does not turn. Do I have a clutch pack problem or a hydraulic control valve problem?
