Massey 135 Newbie...how to add rear hydraulic off 3 pt hitch
Patricks
New User
I know this topic has been done many times but I'm confused. I have a 1965 Massey 135 without rear hydraulics. Its not a UK 135. I want to be able to use the 3 pt hydraulics for times that I'm pulling my haybine on my hitch and want to raise it using the cylinder on the haybine.
Is there a kit that will supply the valve and all hoses?
The host here has a kit that looks to have everything you need.
Look in the 135 hydraulics section, there's a kit that is much like the factory set up and then there's a different valve only which youd have to do your own lines
