wiring diagram 12v MF to-30
Here's a link to a thread I had a couple weeks ago, there's a schematic in that thread and another link to more.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=mf&th=171647
when I did mine, I completely eliminated the old regulator.
Remove generator and regulator.
BAT wire from regulator to output post of alternator
If you have a L (lights or load)terminal on regulator, it supplies power to switches. You can also connect it to output of alternator.
Alternator should be negative ground. To switch from positive to negative ground reverse connections on ammeter and coil. Install battery negative ground. With negative ground, coil - to side of distributor
You do not polarize an alternator
yeah so I looked at a wiring harness for another tractor but every time I touch the + post battery cable the tractor wants to try to crank. I wish there was a set in stone wiring diagram for the To-30 with a alt.
Is this the correct wiring diagram? In the URL. If so what do you do with the positive wire coming from the Amt meter going to the regulator b/c I do not have a regulator. I do have a ignition switch
Untitled URL Link
