Newbie question. 555 radiator pressure test
Me again folks
Strongly suspect that the rad has a leak in the bottom of the upper tank. Radiator is removed and am rigging up to pressure test it. was wondering what pressure i should take it up to.
Thanks again
John
Since its a 4 psi system I wouldn't go past 6 psi. If you have trouble locating the leak there is a UV dye that you can put in the radiator with the water. Most auto parts stores should have a UV kit for cooling systems.
