Msboy
New User
Hello everyone I'm looking at replacing all of the throttle linkage parts or atleast start replacing a few parts on the system. I know that the throttle is not or can not be set due to aged parts. Thanks
PARTS BOOK FORM NO. 693 041 M2 is a good start:
Purchased off e-bay...I use the parts numbers, then Google numbers and usually (not always) find the parts:
So what I'm getting out of that is that some company does not make new parts and I will probably have to buy them used. That's for the diagram and info.
The 135 with the Continental gas uses 99% of the same parts for the throttle linkage.
On adjusting the valves you have to pull the gas tank to get the valve cover off to adjust the valves. According to my Continental shop manual the valve lash for the intake, and exhaust valves are .013" hot, .015" cold.
