Baler MF 12- Need Manual THANKS
Louis N.
New User
I am in need of a manual for my MF 12 baler. If anyone has a manual, I'd appreciate a scanned copy.
The main part of the manual I need is the service and upkeep that shows what to grease and re-timing
chains, etc to be sure it's ready for hay season. You could post it here or email me.
Thank you.
I have a manual for the MF #9, but don't have a PDF of it.
Timing should be stamped on the side of the chamber. The ONLY steps to timing the machine are to ensure all the chains are tight and then putting the bolt in the right location in the gear that the packer crank turns.
Oil chains, fork pivots and packer slide, grease PTO shaft and knotters. Knotter shafts all have a hex plugs in them, idea was to grease once a season by putting a grease fitting in the threads after removing the hex plugs on at a time. I just put fittings in them all.
Just saw your post today. We have a manual from our #12, I could mail it to you, $5 plus postage and it's yours. If your close enough I'd even help you work on it, got to know ours pretty well.
Donovan from Wisconsin
