Massey Harris 44
MikeL.
Looking for steering gear box for a Massey
Harris 44 standard. Pretty slipped out
unless there is a way to tighten anything.
Do not know much about them. Any help will
be appreciated.
Ones not worn out are pretty much non existent.
You can adjust them, crank as much slack out without binding on the ends.
Most have a lot of wear in the entire steering shaft....check the u joints and the pin that fastens them to the shaft. These sometimes make up half the play in the steering. Ben
The top of the sector gear was rounded off on the WF I got, which let it rock. I should have got it welded up and reground so it fit into opening on top, maybe sometime.
Any ideas on seal and gasket kits for rearend, I need a throttle and axles seals and just about every seal.
