RandyB(MI)
Ok , so read through all the archives on this. I have the pedal freed up and but it will only hit the actuator in axle hsng. and then back the 1/4" the other way but will not push or pull the actual actuator. I can turn the actuator in and out which I assume is the adjustment only. Is it stuck inside ? What will it hurt to press in with hyd porta-power to free up. What exactly is inside hsng and what makes it release when you turn front wheels ? Not really looking forward to tearing axle hsng off to fix this. Probably just do without it if that's what it takes. Thanks , in advance , for any / all advise.
