When my tractor sit ls gor awhile i can go
start it and it pops right off with out even
choking it... it will run good and idle for
around 3 to 5 minutes then it kills and i
need to choke it to start and it will only
run on full choke. Then it wont even run
with the choke after about a minute. Il have
to let it sit for a long while before trying
ahain and it will usually pop right off
again after sitting.. i took the carb off
and sprayed cleaner in it but im unfamiliar
with taking it apart. I also drained the gas
and filled up with fresh gas. Still doing
the same thing
the same thing
