Massey 175 UK power steering cylinder port size
C Elliott
Went ahead and purchased the UK175 power steering cylinder. This cylinder requires BSPP Banjo fittings. Does anyone know the size of these fittings? Would like to order adapters to JIC before cylinder arrives.
Thanks for any info.
Where you got the cylinder from does it say exactly what threads are required? (for example 3/8" bsp). Maybe give them a phone call to see what size you need. Since it's probably a aftermarket cylinder they may have changed the threads from the original part had.
Thanks so much guys for the information. I called the vendor and they didn't know the port size and wouldn't look. Cylinder has been shipped and should be in my hands in less than 3 days so I will just wait and measure it then. Hopefully I can find the banjo bolts, and JIC adapters quickly to get it going.
