I'm assembling my engine with new components. The book specifies .018- .022 gap for the top ring and .014- .019 for all other rings. The top rings are good with around .020. The other compression rings are about the same which puts them slightly out of spec but I suppose I can live that. What concerns me (not much) is that The oil rings are running around .012-.013 which makes the a tad tight. The rule of thumb is .003- .004 per inch of bore so the minimum should be 3.875 x .003 = .0116 That would mean I'm OK. Perkins likely figured the ring gaps with an engine running at full power in high heat conditions. This tractor will have a relativity easy life. So am I worrying too much?
Thanks
Thanks
