My 135(20) has had the alternator swapped out for a single wire unit, does anyone know where to find a good schematic to do a re-wire utilizing this?? I assume this means it has internal voltage regulator?
I can probably do it without one...but I'd rather have something to check myself against.
As I was working on the tractor today, it became apparent that it needs a complete re-wire, and this would be the perfect time to get all the now unused wiring out of there, along with the old regulator.
Also on a 135 Perkins gas, is the wiring supposed to be routed behind the starter? This one has al the wiring between the started and carb, and the throttle/governor rods were rubbing on some of the wires. It seems that running the wires between the starter and block would be a good route.
