Pic of MF203 if you are interested
fpappal
Thought I posted this a few days ago but looks like it never went through. Here is my 1961 MF203 enjoying retirement. It worked most of its life in a gravel bed and was not babied one bit. My uncle bought it from the gravel bed and I bought it from my uncle. Too many dollars later it is essentially a new tractor and I use it on my little hop yard. The homemade basket works great to get me up to 18ft. Those are old potato bushels. I like to see pics of these old tractors actually working and thought some of you on this forum would too.
That's what Inno needs to do. grow hops.
Did that one ever have 'work bull' decals? I like the heavy grill, good job.
(quoted from post at 20:07:19 05/03/17) That's what Inno needs to do. grow hops.
That's a good idea, might keep me from messing up the yard every time I try to make improvements.
The heavy grill is just what I have on the 202 and now the 204.
Good looking tractor. And we love seeing pictures!!
The only decal on the tractors was the one on the hood that said "Massey Furgeson 203". The heavy grill is an understatement! I
had to use my engine hoist to remove it from the tractor.
That basket cost me $100 to make. My buddy donated the steel for the frame and coincidentally he is also a welder. So I cut the
pieces and he welded them all together for free. The baskets where $8 each from a potato farm. The most expensive part was the
two pieces of angle iron I needed for the basket frame. Those tires are loaded and each wheel weight is around 500 lbs and the
back end is still a little on the light side when I am up that high.
(quoted from post at 18:58:10 05/03/17)
I also have a 202 with that heavy grill on it. It was kind of a PIA though when I needed to drain the radiator. I couldn't get at the drain cock which is supposed to be somewhere on the bottom, up under that grill. I had to use the petcock on the right side of the block.
